Looking for program file of XDS510PP eeprom
what format is the xds510pp eeprom bin file?
xds510pp
Attached are the eeprom and the GAL files, this works!!
The eeprom file is in binary format, not intel hex.
the GAL file is in the JEDEC format.
Debug this thing is not easy, but you can download some useful tools to test the smc34c60 from the SMSC site. www.smsc.com
regards
PD: Be sure that the eeprom is in 8bit mode
REQ: XDS510PP eeprom
You can use (Holtek Semiconductor Inc.) HT93LC46
Hi all,
I'm new to this forum.
I have a SD XDS510PP board that does not respond to SDConfig, I get:
"Invalid Port Configuration."
SD Tech support says the hardware is dead?
I scoped on a few pins, and the PP controller seems to get input when I run SDConfig.
The EEPROM never gets any input, even when re-booting.
I'm guesing that is not good?
None of the GAL inputs ever toggle.
The PP controller runs a little warm, is that reasonable?
Well, I've downloaded a few files GAL/EEPROM, and I plan to find a PP controller diag software (www.smsc.com)
Any suggestions would be appreciated.
Thanks
