- Joined
- Jul 4, 2009
- Messages
- 16,491
- Helped
- 5,157
- Reputation
- 10,347
- Reaction score
- 5,207
- Trophy points
- 1,393
- Location
- Aberdyfi, West Wales, UK
- Activity points
- 139,515
Re: Logic Probe That measures HI Z impedance
Oh dear - back to square one. :|
Yes, you can do that but only if the power is turned off - so how do you know if the device is being driven or not?
Please listen to what everyone is telling you:
1. There is no such thing as a floating input. It would be a design error, not a fault condition.
2. The ONLY circumstances where an output should ever float is if the pin is tri-stated. That is an intentional state, it does not happen by accident. You should see if the conditions to make the pin tri-state are present to see if the device is working properly or not. If it is being told to be tri-state yet still producing output the device is faulty. If it isn't being told to be tri-state and it is producing no output the device is faulty.
An Ohm meter is not a logic analyser and never will be, in fact connecting one to a live circuit could damage that circuit or the meter.
Also consider WHY the output of a device may have a built in tri-state output. It is so more than one output can be joined together without them "back driving" each other. In that case, it isn't unreasonable to assume that somethng else is connected to the tri-state output and you could be measuring that instead of the pin you think you are.
Brian.
Brian.
