infinite_gbps
Member level 3
So I had a narrowband antenna, Q approx equal to 20 and my frequency is 300 MHz. My impedance at 300MHz is 60.95 - j45.75. BUT, my impedance changes significantly when I move off 300MHz.
My issue is that the LNA will see high kOhms when I open a switch on the antenna (receive antenna).
What should I be concerned about when it comes to LNA stability (or lack there of) when the antenna is open (due to switch) and the impedance is high around that frequency.
Can I do anything about it? I was thinking about plotting K-factor of the amplifier with the s2p files by terminating the output with 50Ohms but putting S11 of the antenna when it is open and see how the k-factor changes with frequency.
This makes sense. Would like to do it in ADS but I have to setup the analysis properly.
Any feedback would be well appreciated.
