neazoi
Advanced Member level 6
Two parallel diodes wired opposite ways around across the headphone is the simplest solution but you MUST add a series resistor or risk the amplifier dumping high current into them.
The trouble with RF AGC is:
1. changing the pre-amp characteristics will alter the detector stage so you need to keep an uncontrolled buffer stage between them. In other words add AGC to a new stage before the existing pre-amp.
2. where do you get the signal strength measurment from? You might be able to extract some RF from the emitter of the detector stage but you would again have to buffer it to reduce it's loading effects then rectify and probably amplify it as well.
3. consider what happens to the perceived signal strength when you deliberately increase the regeneration to receive CW or SSB. The oscillation would be thousands of times stronger than the signal you were trying to measure. The AGC would be the oscillator level, not the incoming signal level.
If you are still there right now, I am monitoring 14.255MHz at the moment but only for a short while!
Brian. (GW6BWX)
We cross posted. Yes I see the limitations with it, I would better not use it at all.
I am at work right now, so I have no access to the transceiver. I built a simple box that converts CW tone to PTT and has some transformer isolation for the audio. It works ok for ON/OFF keying but not for SSB, so I will do it by ON/OFF the TX not modulate it by the tones.
I have not done any test on air, but we won't go high speed CW anyway.
I just found your website, I will send you a PM there to arrange the QSO, to test the Schematix program.
Regards!
Kostas sv3ora
