c_mitra
Advanced Member level 6
I put the value at 6.8 -> 8.2 ohms for a 3A max transistor. Does that sound about right before I go and solder them in?
Major part of the current passes through the collection -emitter path (ignore the base for the time being as a first approximation)- 3A passing through 7 ohm will produce a voltage drop of 21V. This is therefore too high value. The potential at the emitter will be roughly 21V and the base need to be higher still...
You need a resistor in the range of 0.5 ohm (use a 2-3W capacity). Also see post #18.
