engr_joni_ee
Advanced Member level 3
- Joined
- Nov 3, 2018
- Messages
- 831
- Helped
- 2
- Reputation
- 4
- Reaction score
- 7
- Trophy points
- 18
- Activity points
- 6,955
I would like to understand how do the linear power supplies actually work.
I know that there are two main types of lab power supplies.
1- Linear PSU (Power Supply Unit)
2- SMPS (Switch Mode Power Supply)
The linear power supply can have various options and features available for example.
1.1 Voltage Limit - also known as Constant Voltage (CV)
1.2 Current Limit - also known as Constant Current (CC)
1.3 Voltage Readout
1.4 Current Readout
1.5 Remote sensing
1.6 Remote programming
I have attached a circuit diagram that represents the basic design of linear power supplies.
The electronic components in the attached circuit diagram are:
1.1.1 Input power transformer, T1
1.1.2 Bridge rectifier, D1-D4
1.1.3 Reservoir (or smoothing) capacitor, C1
1.1.4 Pass transistor, Q1
1.1.5 Output voltage sense and feedback, Q2
1.1.6 Voltage limit setting, VR1
1.1.7 Voltage reference, ZD1
There are few things I know regarding the attached circuit.
- The input is 220 V AC which is connected through a fuse to the input of the Transformer T1.
- The ratio of number of turns of primary and secondary coils in Transformer T1 decide the output voltage level at the secondary coil of the Transformer T1. For example if the ratio is 22:1 then the 220 V AC will be down to 10 V AC.
- The bridge rectifier consisting of diodes D1 to D4 will rectify. The ripples will be smoothen by the filter circuit or a large capacitor C1 (1000 uF) as mentioned in the attached diagram.
I am wondering what is the formula to calculate Vout provided the values of resistors R2, R3, R4, Potentiometer, and reference voltage 5.1 V are given ?
I understand that Q1 is pass transistor and Q2 is feedback transistor in the attached circuit.
Something more I know is how it work in linear regulator in which we also has a pass element (a transistor) and error amplifier (an OpAmp).
As the output voltage of the linear regulator drops the voltage divider's mid point voltage will also drop that will be compared with the reference voltage, making the error amplifier output low which will turn on the pass transistor, making the output voltage level increase.
As the output voltage level increase beyond the set value. The mid point voltage of the voltage divider will also increase that will be compared with the reference voltage, making the error amplifier output high which will turn off the pass transistor, making the output voltage level drop. This is how the linear regulator work.
Now I need to understand how the linear power supply's attached circuit work. I guess the operation of the attached circuit diagram is also similar but I am not getting it completely.
Can someone please explain how the circuit works ? and how do we calculate the Vout with the values of resistors R2, R3, R4, Potentiometer, and reference voltage 5.1 V ?
Thanks in advance.
1.3 Voltage Readout
1.4 Current Readout
1.5 Remote sensing
Thanks in advance.
