b4bb4ge
Full Member level 2
- Joined
- Feb 28, 2008
- Messages
- 128
- Helped
- 30
- Reputation
- 60
- Reaction score
- 16
- Trophy points
- 1,298
- Location
- Colorado, USA
- Activity points
- 2,050
Hello,
I am sorry for what seems to me like a beginner question but I can not seem to figure it out. I am trying to linearly increase a signal frequency from 50Hz to 100Hz but when I do this it does not seem to work. Here is my code and the lines in bold are the lines that are linearly increasing the frequency from 50Hz to 100Hz.
clear all;
close all;
Fs = 20000; % Samples Per Second
T = 1/Fs; % Sample time
time = 10; % seconds
t = linspace(0,time,Fs*time); % Time vector
freq_increase = linspace(50,100,length(t)); % frequency increase
y = sin(2*pi*t.*freq_increase); % frequency with frequency increase
plot(t,y)
axis([9.9 10 -1 1]
However if you do the FFT of this you will see that the frequency increases from 50Hz to 150Hz why is this?
NFFT = 2^nextpow2(length(t)); % Next power of 2 from length of y
Y = fft(y,NFFT)/length(t); %fft of signal vector
f = Fs/2*linspace(0,1,NFFT/2+1); %set correct frequency
figure
plot(f,2*abs(Y(1:NFFT/2+1)))
title('Single-Sided Amplitude Spectrum of y(t)')
xlabel('Frequency (Hz)')
ylabel('|Y(f)|')
axis([0 200 0 .1])
If I replace the code with this
freq_increase = linspace(50,75,length(t)); % frequency increase
The frequency increase from 50Hz to 100Hz. Why is this code working and the previous code not working? I would expect for y = sin(2*pi*f*t) where f is the frequency. however as you can see the upper frequency is not relating to this but the lower frequency is relating to this?
Thank you for your help.
clear all;
close all;
plot(t,y)
axis([9.9 10 -1 1]
figure
ylabel('|Y(f)|')
axis([0 200 0 .1])
