[SOLVED] LCD with PIC16F877A problem
Hey
Now I'm using MicroCode studio Compiler
This is my code
' Sonar-ranger.bas
' Program to control the Devantech SRF04 ultrasonic module. Measure
' the distance between the the unit and an object. Convert the raw
' data to inches and centimeters and then send the results to an LCD
' display. PicBasic Pro Compiler by MicroEngineering Labs. The
' conversion factors listed in the SRF04 manual are for the PULSIN
' of a Basic Stamp II which measures in 2us increments. When running
' a PICmicro MCU at 4 MHz and using the PicBasic Pro compiler the
' PULSIN command measures in 10us increments and the PULSOUT command
' also generates pulses with 10us increments. The adjusted conversion
' factors for 10us increments are:
' inches = raw_data / 15
' centimeters = raw_data / 6
'in picbasic stamp "  convert to inch ---> 1 / 73.746
'                     convert to cm ---> ' 1 / 29.034
'10us in picbasic pro but in basic stamp 2us for pulse so :
'The adjusted conversion factors for 10us increments are:
' inches = raw_data / 15     ' 73.746 / 5   =~ 15
' centimeters = raw_data / 6  ' 29.034 / 5 =~6
 'Set LCD Data port
DEFINE LCD_DREG PORTB
' Set starting Data bit (0 or 4) if 4-bit bus
DEFINE LCD_DBIT 4
' Set LCD Register Select port
DEFINE LCD_RSREG PORTB
' Set LCD Register Select bit
DEFINE LCD_RSBIT 1
' Set LCD Enable port
DEFINE LCD_EREG PORTB
' Set LCD Enable bit
DEFINE LCD_EBIT 0
' Set LCD bus size (4 or 8 bits)
DEFINE LCD_BITS 4
' Set number of lines on LCD
DEFINE LCD_LINES 2
' Set command delay time in us
DEFINE LCD_COMMANDUS 2000
' Set data delay time in us
DEFINE LCD_DATAUS 50
trisa = %00000001
TrisB=0
Buzzer   var PORTA.1
' variables adapted for PING)))(TM) Ultrasonic Range Finder (#28015) by Kenneth Wong (2006/06/07)
' trigger      var PORTB.2
' echo         var PORTB.3
sonar       VAR PORTb.2
dist_raw     var word
dist_inch    var word
dist_cm      var word
conv_inch    con 15
conv_cm      con 6
Lcdout $fe,1           			' clear lcd screen
pause 1000						' give time to initialize lcd
Lcdout $fe,$80,"- Sonar Ranger -"		' display program title on the LCD
sound Buzzer,[100,10,50,5,70,10,50,2]			' Make startup sound
pause 1000						' wait for 1 second
Lcdout $fe,1
Lcdout $fe,$80,"inches:"   	' set up the LCD display
Lcdout $fe,$C0,"cent:"
main:
     gosub sr_sonar					' get sonar reading
    Lcdout $fe,$89,#dist_inch," Inch "		' display the distance in inches
    Lcdout $fe,$C7,#dist_cm," cm "		' display the distance in centimeters
Goto main
sr_sonar:
' I/O assignments adapted for PING)))(TM) Ultrasonic Range Finder (#28015) by Kenneth Wong (2006/06/07)
        output  sonar               ' set sonar pin as output
        low     sonar               ' logic low for sonar pin
        pulsout sonar,1				' send a 10us trigger pulse to the SRF04
        input   sonar               ' set sonar pin as input
        pulsin  sonar,1,dist_raw	' start timing the pulse width on echo pin
         dist_inch = (dist_raw/conv_inch)		' Convert raw data into inches
         dist_cm = (dist_raw/conv_cm)		' Convert raw data into centimeters
         pause 1					' wait for 10us before returning to main
return
end
It seem that this have something to do with the type of LCD used
I have the same project running on 20 Mhz and working fine with a different type of LCD !!
Even though I tried 3 different type till now
Thanks for you help
the problem was with my hardware, I changed the PIC with a new one and everything worked just fine.
