karesz
Advanced Member level 5
Re: LC meter
The answer will exists in all cases as a voltage transient, with amlitude depending of parasitics & not from kind of physical realising: Tr or Manual switch....
I will not say that a serial resistor(if its real existent in the Meter) can not attenuat it, but a diode not to design into these circuit i for me clearly=a failure!
K.
Sorry; I can not agree with you, because for the inductance its really equal if you are switching it per transistor or a manual switch onto some potential!mvs sarma said:@ Karesz,
if you see the circuit uploaded by sanjubluerock3, the relay Calibhas a diode across the coil as it is expected to be operated by the transistor. Perhaps other one it is not needed as it is manually switched. Hope, this clarifies.
K.
