PNU7
Newbie level 3
hi guys, i am quite new new in the LPF field.. i need help in design consideration to generate 50HZ sinewave for Inductor(MOTOR).
i am switching(CHOPPING RATE) transistor at 20KHZ, my PWM FREQUENCY is 1KHZ and my number of samples are 20... so that way my output frequency would be = 1KHZ/20= 50HZ... but i dnt know what value of L and C i must be using to generate 50HZ across INDUCTOR(MOTOR)..so i want to design the filter which will eliminate 20khz COMPONENT and generate 50HZ sinusoidal wave.
