Laptop schematic here
this may help you ?
TOSHIBA Satellite A210 A215 - COMPAL LA-3631P IALAA - REV 1A
  • TOSHIBA Satellite A210 A215 - COMPAL LA-3631P IALAA - REV 1A.pdf
Friend I am sorry, I just checked but the schematic dont match the processor as well other peripheral. the schematic supports tuiron family. mine is Athlon 2X
And to Athlon and tuiron are not compatible with each other. pls correct me.
hcl notebook y20 amd power suppl problem. when connect dc the led flicker this is short in board r where is the problem i dont know pls help me thanks in advance
check dc socket i thing their is shorting verious time . if you found short on dc input socket then cut +ve pin from socket and solder one thin wire on socket + pin and on pcb you remove +ve ceramic fuse and conect wire to circuite end ( actual problem is pcb short so do by pass that conecting area .) sorry i am not good writer of english i hope you understande what i want to say
@ Li_ereunpisan,
sorry at that time i hadn't it.
now check with this.
  • DELL N4030-Arsenal DJ1 DIS.pdf
  • N4030-UMA.pdf
here is toshiba c665
  • Toshiba Satellite C660 - COMPAL LA-6842P PWWAA - REV 0.2.pdf
  • HP_550.pdf
Hi, any chance for a LGe50/e500 Laptop schematic?
Like in these images:
http://www.zuoda.net/search.aspx?q=lg+e500
http://index.braun-omnibusse.de/ebay/lg3.jpg
http://img2.sprzedajemy.pl/540x405_obudowa-gorna-lg-e-l-718957.jpg
Model: LGE50
Config: E500
Thank you very much.
please give the motherboard model no.
Model: LGE50
Config: E500
sir please post schematics for toshiba dynabook satellite 1800 series
why other people making comment like that?instead they should be thankful for baraka42's effort to share these things in here..just continue what you're doing baraka42..
