kak111
KMA210 Programmable angle sensor
angle resolution 0.04 deg max.
programmable angular range 180 deg max.
The KMA210 is a magnetic angle sensor module. The MagnetoResistive (MR) sensor
bridges, the mixed signal Integrated Circuit (IC) and the required capacitances are
integrated into a single package.
This angular measurement module KMA210 is pre-programmed, pre-calibrated and
therefore, ready to use.
The KMA210 allows user-specific adjustments of angular range, zero angle and clamping
voltages. The settings are stored permanently in a non-volatile memory.
