ADIS16488: Low Profile, Low Noise Ten Degrees of Freedom Inertial Sensor
kak111
Finland
Triaxial, digital gyroscope with digital range scaling
- ±450°/sec dynamic range
- <0.05° orthogonal alignment
- ~6°/hr in-run bias stability
- 0.3°/√hr angular random walk
- 0.01% nonlinearity
Triaxial, digital accelerometer, ±18 g
Triaxial, delta-angle and delta velocity outputs
Triaxial, digital magnetometer, ±2.5 gauss
Digital pressure sensor, 300 mbar to 1100 mbar
Fast start-up time, ~500 ms
Factory-calibrated sensitivity, bias, and axial alignment
- Calibration temperature range: −40°C to +70°C
SPI-compatible serial interface
https://www.analog.com/static/imported-files/data_sheets/ADIS16488.pdf
