anotherbrick
Full Member level 4
- Joined
- Jan 10, 2009
- Messages
- 222
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,298
- Location
- Istanbul , Turkey
- Activity points
- 3,190
hello dear Forum ,
I am sending 2 photos ( up and downside )of my circuit
I have 2x H bridges with IRF3205
as you can see the 24V is entering the circuit beside the relay
and GND is entering at the bottom of the circuit
I am driving electric wheelchair motors
I am measuring the current into H bridge with ACS7xx sensor and if it is more than 25 Amps
I am decreasing the PWM duty
as you can see one of the H bridges is burned ( I have cut the IRF3205s and ACS7xx)
I am using IR2113 to drive the FETs
the accu voltage is 24 V - the gate voltage is 12 V with LM2575-12
at the output of IR2113 there is 22Ohm to the gate
and parallel to 22 Ohm a 1N4148 direction to the IR2113
i.e cutting off FET faster than turning on
what can you say to me ?
is there a layout problem ?
can the IRF3205 be fake ?
please advice
thank you
note : I forgot to say the FETS are cooled with enough aluminium case
please advice
thank you
