IR2110 test for driving mosfet
Yes you can use IN4007 it works fine
hi,
i'm gonna use ir2110 for driving my bldc h-bridge.
so for testing, i connected it with mosfet like this:
i fed the Lin pin with 60Hz noninverting PWM signal, and 60Hz inverting PWM signal for Hin pin.
for bootstrap capacitor, i use 0.1uF ceramic and 47uF electrolytic in parallel.
but both of the mosfets got pretty warm in few seconds, and then damaged.
need help :|
anyone?
In this schematic the DC input has to be a split supply. This has to be in a half bridge configuration. The supply must have both +ve and -Ve DC supply with a center as neutral. This neutral will connect to one end of the Load (usually a transformer). And the junction of the mosfets connect to the other end of the load.
