Interfacing PIC18LF4550 to 16x2 LCD
Akhil Mohan
Member level 2
Hello,
I am trying to interface a PIC18LF4550 with a 16x2 LCD display (h as a JHD162A Processor) in the 4 bit mode. I am using PICkit 2 for programming which loads the hex code in to PIC. I have done some modifications to the code that I got (this code I got it from PyroElectro.com), but, the display shows nothing and am not sure where is the mistake. Could you please help me to resolve this ?
#include <htc.h>
#include<delays.h>
#include <pic18F4550.h>
#define E_PIN    PORTDbits.RD6   /* PORT for E  */
#define RW_PIN   PORTDbits.RD5   /* PORT for RW */
#define RS_PIN   PORTDbits.RD4   /* PORT for RS */
#define _XTAL_FREQ 20000000
__CONFIG (1, FOSC_HS);
__CONFIG (2, WDTDIS & PWRTEN & BOREN & LVPEN);
void prnt(unsigned int);
void commd(unsigned int);
void lcd_init(void);
void Delay10KTCYx(unsigned char unit);
void Delay1KTCYx(unsigned char unit);
void main(void)
   int count=0;
   int marquee_1 = 0;
   int dir_1 = 0;
   char output[] = " Hello ";
   char output2[] = " World !! ";
   TRISD=0x00;
   PORTD=0x00;
   Delay10KTCYx(200); // After Power On, this instruction will give 16ms delay
   lcd_init();
   while(output[count] != '\0')
   prnt(output[count]);
   count++;
   commd(0b11000000);   //Move 2nd Next Line
   count = 0;
   while(output2[count] != '\0')
   prnt(output2[count]);
   count++;
   commd(0b10000000);
   while(1)
   if(marquee_1 == 0)
      dir_1 = 1;
   if(marquee_1 == 9)
      dir_1 = 0;
   if(dir_1)
      commd(0b00011100);
      marquee_1++;
   else
      commd(0b00011000);
      marquee_1--;
   Delay10KTCYx(200);
void lcd_init(void)
E_PIN = 0;
RS_PIN = 0;
RW_PIN = 0;
commd(0b00100000); //
commd(0b00101100); // Function Set
commd(0b00001000); // Display OFF
commd(0b00000001); // Display Clear
commd(0b00000110); // Entry Mode Set
//4-bit print interface
void prnt(unsigned int character)
PORTD=character >> 4;
RS_PIN = 1;
RW_PIN = 0;
E_PIN = 1;
E_PIN = 0;
PORTD=character & 0x0f;
RS_PIN = 1;
RW_PIN = 0;
E_PIN = 1;
E_PIN = 0;
Delay1KTCYx(200);
//Delay1KTCYx(1); //The Delay Above Is Only To
              //Create The Type-Writer Effect
//4-bit instruction interface
void commd(unsigned int commd)
PORTD=commd >> 4;
RS_PIN = 0;
RW_PIN = 0;
E_PIN = 1;
E_PIN = 0;
PORTD=commd &0x0f;
RS_PIN = 0;
RW_PIN = 0;
E_PIN = 1;
E_PIN = 0;
Delay1KTCYx(10);
Thanks in Advance :)
Akhil
