buenos
Advanced Member level 3
- Joined
- Oct 24, 2005
- Messages
- 962
- Helped
- 40
- Reputation
- 82
- Reaction score
- 24
- Trophy points
- 1,298
- Location
- Florida, USA
- Activity points
- 9,142
architecture beh of appln is
signal empty_int,full_int : std_logic;
signal wr_ptr, rd_ptr : std_logic_vector(3 downto 0);
signal wr_en, rd_en : std_logic;
signal wr_clk, rd_clk : std_logic;
component DPRAM
port
wr_clk : in std_logic; -- Clock to input port
rd_clk : in std_logic; -- Clock to output port
wr_en : in std_logic; -- Write enable
rd_en : in std_logic; -- Read enable
wr_ptr : in std_logic_vector(3 downto 0); -- write address
rd_ptr : in std_logic_vector(3 downto 0); -- read address
din : in std_logic_vector(7 downto 0); -- write data
dout : out std_logic_vector(7 downto 0) -- read data
end component;
begin
U_DPRAM: DPRAM
port map
wr_clk => wr_clk,
rd_clk => rd_clk,
wr_en => wr_en,
rd_en => rd_en,
wr_ptr => wr_ptr,
rd_ptr => rd_ptr,
din => din,
dout => dout
just declare with the original top-level filename, and install? or do i ahave to do something else too?
* Low Level Synthesis *
Reading core <wbp.ngc>.
Reading core <pci32tlite.ngc>.
Loading core <wbp> for timing and area information for instance <the_intercon>.
Loading core <pci32tlite> for timing and area information for instance <the_pci>.
