Starset
Newbie level 6
How should I add power IO in innovus?
I use tsmc n28 hpc+ pdk library, and i add the power IO in netlist like this:
VDD and VSS is to drive the core, VDDPST and VSSPST is to drive the IO block.
And my IO block is connected as below in netlist file:
however, the power IO is still not connected to the power net and there is no pin displayed on the power IO, should I use the createPhysicalpin command? and how should i edit the globalnetconnect command so that i can make the power IO connect to the functional IO and the power net
