inline assembly instructions
ayan_m
Newbie level 6
Newbie level 6
How can I write inline assembly instructions in C in Keil (uvision 2)?
ayan
read the sections about #pargma asm in the manual.
I can not see any reason wy this should be neccessary. Its always beter to write an extra asm module if you need the power of ASM
usbman
Sometimes it is easy to write inline assembly instead of writing a full module. For example, if you want to rotate an array of 5 bytes. You could do
void rotate_array(bit c) {
#asm
MOV R0,#array
MOV R6,#5
LOOP: MOV A,@R0
RRC A
MOV @R0,A
INC R0
DJNZ R6,LOOP
#endasm
I dont know if this can be done in k*el
thats easy
void rotateRight (UINT8 value)
    UINT8 i;
    for (i=0;i< 6;i++)
         if (value & 0x01)   P1_1=1;
         else                     P1_1=0;
         value >>=1;
usbman
First of all, your C code does not do what I did in the ASM routine.
Second of all, the point is not that it cannot be done in C. Almost everthing that ASM does can be done in C. But sometimes you need to do things in a more efficient manner. You have to use ASM. Sometimes, there is just no choice. C is too slow and too bloated for some operations.
Hi
Insert asm code like below:
#pragma asm
;assembly code goes here
#pragma endasm
This also requires source control to be active (as the compiler error proudly announce). To do this, right click on the file where you inserted the asm code (in the project workspace window) and from the <option for file "whatever_your_filename_is.c"> select "generate assembly SRC file" and "assemble SRC file"
Best Regards
