thannara123
Advanced Member level 5
- Joined
- Jan 7, 2010
- Messages
- 1,602
- Helped
- 122
- Reputation
- 244
- Reaction score
- 116
- Trophy points
- 1,353
- Activity points
- 10,633
Re: In 16x2 Lcd ,how to refresh the values at point only other value remains stable
Sorry , I am posting the code here where i need to implement the technique or code as i asked my first post . I didint used that technique here because i use another code to test it .And i posted above .
the whole project is uploaded here.
Also notyfy any better way to do the whole program efficiently
* File: adc_main.c
* Author: Krishna
* Created on September 27, 2015, 6:24 AM
// PIC16F877 Configuration Bit Settings
// 'C' source line config statements
#include <xc.h>
#include"lcd.h"
#include"adc.h"
#include <stdlib.h>
#define _XTAL_FREQ 20000000 // 20Mh
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
// CONFIG
#pragma config FOSC = HS // Oscillator Selection bits (HS oscillator)
#pragma config WDTE = OFF // Watchdog Timer Enable bit (WDT disabled)
#pragma config PWRTE = OFF // Power-up Timer Enable bit (PWRT disabled)
#pragma config CP = OFF // FLASH Program Memory Code Protection bits (Code protection off)
#pragma config BOREN = ON // Brown-out Reset Enable bit (BOR enabled)
#pragma config LVP = OFF // Low Voltage In-Circuit Serial Programming Enable bit (RB3 is digital I/O, HV on MCLR must be used for programming)
#pragma config CPD = OFF // Data EE Memory Code Protection (Code Protection off)
#pragma config WRT = OFF // FLASH Program Memory Write Enable (Unprotected program memory may not be written to by EECON control)
void main()
{ unsigned char volt[5] ,current[5];
int v,i;
TRISB = 0X00; // output for the 8 bit
TRISA =0XFF;
int adc_value=0x00;
unsigned char digits[5];
lcd_init(); // lcd initialization
adc_init(); // adc initialization
string("gElectron ");
while(1)
LINE2;
CLEAR
//while(1)
v = read_adc(0); // reading voltage
i = read_adc(1); // reading voltage for current
v = (v * 4.89 * 2.4)/10;
i = (i * 2.92);
i = ((i*4.89)/0.47)/10;
if(v< 1200)
volt[0] = ((v /1000)%10)+0x30;
volt[1] = ((v /100) % 10) + 0x30;
volt[2] = '.';
volt[3] = ((v/ 10) %10) + 0x30;
volt[4] = (v % 10) + 0x30 ;
string("Volt : ");
for(int i =0; i<5;i++)
lcd_data(volt[i]); // just displaying ADC value
string("V");
else
string("Over Voltage");
LINE2;
if(i<3100)
current[0] =((i /1000)%10)+0x30;
current[1] = '.';
current[2] = ((i /100) % 10) + 0x30;
current[3] = ((i/ 10) %10) + 0x30;
string("Current : ");
for(int i =0; i<4;i++)
lcd_data(current[i]);
string("A");
else
string("Over Current");
__delay_ms(600);
CLEAR
