Important parameters of sensor for a hardware design engineer
newbie_hs
Full Member level 1
Our IC design team is developing a sensor based on quantum sensing.
My job is to design a signal conditioning circuit for that sensor and send the sensor data to cloud.
As a hardware design person I need to know the below parameters.
Please let me know am I missing anything?
  1. Sensor output type(Current or voltage and its min and max values)
  2. Output is AC or DC,(if AC it's frequency)
  3. Output Variation
  4. Sensor O/P impedance
  5. Sensor operating voltage
May I know your thoughts.
the most important: a complete sensor datasheet.
It should answer all your questions above.
Klaus
There is no datasheet as of now.
The chip is in the design state.
What I heard from IC design team is the output is current.
Regards
I doubt they design a sensor without a specificaton .. like trial and error basis.
But if they do: you could go the same way: Just build something and hope it works.
Klaus
LaTeX Commands Quick-Menu:
