viperpaki007
Full Member level 5
As far as I know, impedance matching is done in order to transfer maximum power from source to the load and also to avoid signal reflections back to load. Reflections are problem at IC-PCB interface because dimensions of the interface are comparable to wavelength of signal. However, when we go inside the IC and we are operating at lets say 1GHz frequency, IC dimensions are much smaller than signal wavelength. Therefore, reflections should not be a problem. Therefore, I think that impedance matching between LNA and mixer may not be necessary. I have seen people designing cascaded amplifier stages inside the IC in voltage mode (i,e. low source impedance and high load impedance). My question is do we really need impedance power match between the amplifiers inside the IC or can we just design amplifiers in voltage mode interface? signal can be transferred in voltage mode as well so why to do power match?
