adnan_merter
Full Member level 3
- Joined
- Jan 23, 2008
- Messages
- 160
- Helped
- 6
- Reputation
- 12
- Reaction score
- 6
- Trophy points
- 1,298
- Location
- The most beautiful city of the world
- Activity points
- 2,526
The circuit is be operational in principle. However, without knowing the actual circuit wiring, it's difficult to guess about reasons for failure. The 12V supply is missing bypass capacitors, but I hope you have it. What do you exactly mean with "even when i don't apply any gate voltage"? You don't apply a gate voltage in the circuit, only control voltage to the gate driver. Do you mean, all control inputs are tied to ground?
P.S.: As a hint, the first test should be to check the gate driver operation with zero DC bus voltage, the next, to connect a current limited low voltage supply, e.g. 10 or 20 V and check for correct switching operation. You can even drive a motor at low speed with this supply. If both tests pass, precced to high voltage operation.
Regarding optical isolation, without it, your driver circuit (microcontroller, whatsoever) will be directly connected to the mains power supply, so it can't be connected e.g. to a computer at the same time. Also, the control circuit must not be touched because it carries a dangerous voltage level. If you don't want this restrictions, optical isolation of the pwm signals will be required. The other option is to use a safety transformer to supply the DC bus.
I think, it doesn't harm (except for discharging the bootstrap capacitor slightly faster). But if the IR2101 is connected to gates, they can't float respectively ever turn on without an input signal to the driver..Connect a 1k resistor from the gate to source of each MOSFET. This prevents them from accidental turn-on.
There's no doubt, that a MOSFET can turn on in the said way, but the IR2101 is shorting the gate to source more effective than a resistor. I guess the reported cases are not related to circuits with IR21xx or similar drivers. Besides providing protection against unintentional turn-on, gate-source resistors are often placed to prevent the gate from charging to a dangerous voltage, if the driver circuit can be disconnected from power stage.
Same here, I was using IR2110.I used IR2110 in my own designe.
Yea, that's why I always include that 1k resistor from gate to source or gate to emitter in all my designs. Best to be safe.
Tahmid.
