If anybody need help in EAGLE, ask me in this POST !
SyNTaXer
Junior Member level 3
eagle autoplace
i think the topic says enough. i want to give help as long as i can.
bye SyNTaXer :wink:
/ Added by moderator:
Do not upload or discuss illegal files, patches or licenses for Eagle or any other program at elektroda!
If you break this rule you will be banned from elektroda!
eagle polygon rank
I need pcb engraving program for eagle.
Yes eagle has this utility but i dont like it.
I have a good idea Can you write ulp program for eagle.
autoplace eagle
How can I put designs inside other designs?
Thanks!
autoplace in eagle
do you want to use parts of an existing schematic in your new project ?
and later make a pcb of it ?
or you only want to import a part of an existing pcb, without to have a forward/back annotation with schematic ?
expresspcb to eagle
I want to integrate other designs in my design, i need only schematic:)
Thanks!
eagle rj11 library
Hello SyNTaXer,
Yes I need software for my CNC.
I draw a simple PCB using eagle 4.03. (Look in test.zip)
Bottom layer has orginal PCB lines and pads.
I convert this lines manualy and i drow for you, this lines at the top layer.
Manual convertion is diffucult and Outlines.ulp not good (my idea)
I need ulp program for this purpose.
Thanks.
tkeepout
Thanks!
* then open your old reference schematic file with eagle.
* type "group" and select all parts you need
* type "cut" and press right mouse button
* go to eagle "control panel" and now open you schematic where you want to import these parts
* now type "paste"
* and be happy
hope it is what you are looking for
bye SyNTaXer
cadsoft eagle panelize
bunalmis said:
Hello SyNTaXer,
Thanks.
after a long time of thinking i (know) i'm checking.
you want only isolate milling (hope it is right translated from german: isolationsfräsen)
look in the attachment, this time i've made it for you.
open it in eagle, then type "ratsnest" and i hope this is what you want.
next time you should use the command "polygon" to do this.
if dont know how this command work, ask me in this post again.
bye SyNTaXer
load error 291 eagle
If i work with V3.55 all things are right.
Now I have a look at V4.X and there happen some strange things.
When i make zooms or move some parts, some buttons disapear or
some layer are displayed wrong.
If I save the Board and open it again all thing are all right, but after
some movements....
(I work with Win2k Version)
Is there a known problem with displaydriver under win2k in Version 4.x??
eaglecad hide airwire
some movements....
allright, i also had this problem.
* try out the newest version of eagle 4.09r2
* also newest service pack of win2k
* newest graficcard driver for win2k
now it should work fine.
trust me. i also work with win2k and at my start i also had problems like u.
bye SyNTaXer
eagle pcb soic
To: SyNTaXer
Realy wonderfull.
Your test.pcb working but i could'nt new simple drawing.
How work? Polygon command need extra parameters.
Thanks.
made with illegal copy of eagle
How can I put my logo (graphic or picture) into the PCB?
eagle thermals pcb
look at **broken link removed**
pin connect to polygon eagle pcb
Thank you MrAndy.
I have another question.
How can I make or connect sub-circuits in the same project. I can use multisheet to draw the circuits, but how can I connect them together (what connector or symbol to be use) and can I draw a black box to replace the sub-circuit and connect it to the main drawing. If you have some examples please post it or PM me.
eagle pcb autoplace
After smashing parts all part names and values have a crosshair applied to them. This looks very messy. How do I turn off all those cross hairs?
Can you tell me what the major difference is between veresion 4.03 and ver 4.09r2.
Thanx
cadsoft eagle illegal copy
pico said:
Thank you MrAndy.
to pico :u're right. its bad that eagle doesn't use port in/out functions over multiple sheets.
all you can do is. draw your own parts in library.
* one symbol looks like this ---> for port out
* and one symbol looks like this ---< for port in
* without a footprint, in eagle it is called package
* then make a device of each part, one call port_in and one port_out
now u can put it in schematic, but remember this has no effect, it is only for a better overview, where signals go out and come in.
the name of the net, you must rename by hand to get a connection between port_in and port_out lines.
i know, symbols like this are in standard eagle libs, but they are realy shitty.
hope that i could help u,
bye SyNTaXer
pic18f* cadsoft
Thanx
to challenger:
the crosshair after smashing is because the names and values are now like a own part. you can move, change and do what u want with them.
looks messy: hmm, let me think. what can we do here.
i think we could do nothing. but could u tell me, why do you think this looks like messy, i don't think so. i do not attend this crosshairs.
bye SyNTaXer
eagle hide gnd
the crosshairs are the origins of the names and values, you can see it when you rotate a name or value
I don't mind them, because they are really tiny
they don't appear when you print on paper
pcad to eagle
Thanks SyNTaXer for your answer.
I think the crosshairs are used for aligning parts.
eagle drill chart
Hello SyNTaXer,
Did you forget my question?
Can you said to me Polygon command parameters ?
How is works?
My second question, I need negative gerber file.
How can i find negative gerber file from the gerber file.
