IC5.0.32 corner analysis problem
uladz55
Full Member level 3
Full Member level 3
After running corner analysis with Single Model Library style got message:
"Internal error found in spectre during altergroup "normal" ....
please send the netlist, ... to support@cadence.com
Segmentation fault.
How to solve this problem?
I have the same problem.the netlist has somethine wrong,i think is the problem of license
Hai,
This may be due to orientation of the model file when you add in model libraries different foundries have their own style .If the model file not in order as mention in model file it usually give this type of errors .Please do check respective model file.
When i run simulation with the same model library but without corner analysis everything is OK.
After that i run corner analysis. The netlist is the same, the model library is the sme. But get segmentation fault.
What's the reson?
