I want to start ARM with lpc1768 cortex M3
As I wrote in a previous reply the -1 not needed, I don't know where you saw that.
SystemCoreClock represents the frequency that the core runs , for example 100MHz (100000000)
That means 100000000 ticks /sec
For 1ms you want 1/1000 of that so you use 100M/1000 , this is the same as SystemCoreClock/1000
SysTick_Config(SystemCoreClock/1000) will set the SysTick counter to give an interrupt every 1ms
In your keil installation folder browse to ARM\CMSIS (e.g. C:\Keil\ARM\CMSIS) , open the index.htm and select CORE -> Reference -> SysTick , you can read about the function there
there
I saw that here :
http://ics.nxp.com/support/documents/microcontrollers/zip/lpc17xx.cmsis.driver.library.zip
if SysTick_Config(SystemCoreClock/1000) makes 1ms, I should see the LED blinks every 300 ms, but it doesn't blink
what is the problem of my program ?
#include"lpc17xx.h"
#include "lpc17xx_gpio.h"
#include "lpc17xx_libcfg.h"
volatile unsigned long SysTickCnt;
void SysTick_Handler (void);
void Delay (unsigned long tick);
void SysTick_Handler (void) {
  SysTickCnt++;
void Delay (unsigned long tick) {
  unsigned long systickcnt;
  systickcnt = SysTickCnt;
  while ((SysTickCnt - systickcnt) < tick);
int main(void){
 GPIO_SetDir(0, 0x00000001, 1);             /* LED on P1.0 defined as Output    */
 SysTick_Config(SystemCoreClock/1000 - 1); /* Generate interrupt each 1 ms   */
 while(1){
  GPIO_SetValue(0,0x00000001);             /* LED on P1.0 on    */
  Delay(300);
  GPIO_ClearValue(0, 0x00000001);         /* LED on P1.0 off    */
  Delay(300);
So what you refer to is code like
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
void SYSTICK_InternalInit(uint32_t time)
    uint32_t cclk;
    float maxtime;
    cclk = SystemCoreClock;
    /* With internal CPU clock frequency for LPC17xx is 'SystemCoreClock'
     * And limit 24 bit for RELOAD value
     * So the maximum time can be set:
     * 1/SystemCoreClock * (2^24) * 1000 (ms)
    //check time value is available or not
    maxtime = (1<<24)/(SystemCoreClock / 1000) ;
    if(time > maxtime)
        //Error loop
        while(1);
    else
        //Select CPU clock is System Tick clock source
        SysTick->CTRL |= ST_CTRL_CLKSOURCE;
        /* Set RELOAD value
         * RELOAD = (SystemCoreClock/1000) * time - 1
         * with time base is millisecond
        SysTick->LOAD = (cclk/1000)*time - 1;
I'm not sure why they are using this.
In the CMSIS help file in the kail installation folder they use
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
#include "LPC17xx.h"
uint32_t msTicks = 0;                                       /* Variable to store millisecond ticks */
void SysTick_Handler(void)  {                               /* SysTick interrupt Handler.
  msTicks++;                                                   See startup file startup_LPC17xx.s for SysTick vector */
int main (void)  {
  uint32_t returnCode;
  returnCode = SysTick_Config(SystemCoreClock / 1000);      /* Configure SysTick to generate an interrupt every millisecond */
  if (returnCode != 0)  {                                   /* Check return code for errors */
    // Error Handling
  while(1);
You have used the interrupt handler for SysTick but you haven't enabled it.
Try this:
Code C - [expand]
                         Vectored Interrupt initialization
   NVIC_SetPriority(SysTick_IRQn,0);          /* Default priority group 0, can be 0(highest) - 31(lowest) */
   NVIC_EnableIRQ(SysTick_IRQn);           /* Enable System Tick Interrupt */
Actually I'm not sure if SysTick_Config enables the interrupt too and I can't check it right now so try the above code to see if it helps.
I'm also not sure is there may be a problem with the GPIO functions, I have never used them.GPIO
I wrote this program from code bundle,this program used "FOR" for make delay,IS it exactly right?
#include "lpc17xx.h"
#include "type.h"
int main (void)
  uint32_t j;
  /* SystemClockUpdate() updates the SystemFrequency variable */
  SystemClockUpdate();
  LPC_GPIO2->FIODIR = 0x00000001;		/* P2.xx defined as Outputs */
  LPC_GPIO2->FIOCLR = 0x00000001;		/* turn off all the LEDs */
  while(1)
	  LPC_GPIO2->FIOSET =0x00000001;
	  for(j = 1000000; j > 0; j--);
you would want to declare j as a volatile to avoid optimization of the loop, when the compiler finds a loop that serves no purpose and makes no difference in the code execution it can remove it.
So the SysTick method didn't work?
So your code didn't work?
In a couple of hours when I get home but I don't have a LPC1768 device so I can only check it in the simulator.
When I tried your code from post #42 in Uvisionn 4.60 I got an error that SystemCoreClock is undefined.
The correct variable that holds the frequency in 17xx is SystemFrequency but to use it you have to use SystemClockUpdate(); first.
For some reason the SystemFrequency is reported as 99MHz instead of 100MHz so the calculations are not accurate, if you want you can use SysTick_Config(100000000/1000)
I have attached the working project, just change the delays back to 500
  • Copy of GPIO.zip
thanks my friend alexan for every thing,the only problem was about the following sentence that I didn't write
what do you suggest for calculating delays accurately ? I should use timer for that?
In the LPc23xx code bundle you will find the following function
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
void delayMs(BYTE timer_num, DWORD delayInMs)
  if ( timer_num == 0 )
    * setup timer #0 for delay
    T0TCR = 0x02;       /* reset timer */
    T0PR  = 0x00;       /* set prescaler to zero */
    T0MR0 = delayInMs * (Fpclk / 1000-1);
    T0IR  = 0xff;       /* reset all interrrupts */
    T0MCR = 0x04;       /* stop timer on match */
    T0TCR = 0x01;       /* start timer */
    /* wait until delay time has elapsed */
    while (T0TCR & 0x01);
  else if ( timer_num == 1 )
    * setup timer #1 for delay
    T1TCR = 0x02;       /* reset timer */
    T1PR  = 0x00;       /* set prescaler to zero */
    T1MR0 = delayInMs * (Fpclk / 1000-1);
    T1IR  = 0xff;       /* reset all interrrupts */
    T1MCR = 0x04;       /* stop timer on match */
    T1TCR = 0x01;       /* start timer */
    while (T1TCR & 0x01);
  return;
You just need to define the Fpclk which represents your clock frequency and change te register names to the ones for your mcu.
T0TCR to LPC_TIM0->TCR , T0PR to LPC_TIM0->PR etc , the same for timer1
thanks for your reply
I read that each "FOR" instruction execute in the 4 clk,Is it true?and can we use this for get delay accurately?
Thanks in advance
I have discussed about a loop delay some time ago in the LPC2000 yahoo group.
After a lot of discussion I was provided with the following function that takes four clocks per loop and made a couple of macro based on it
	AREA DELAY, CODE, READONLY
delay4 PROC
	EXPORT delay4
	subs R0,R0,#1
	bne delay4
	BX LR
	ENDP
	END
Save this to an s file , for example my_delay.s as it is with the spaces in front of all lines except delay4 PROC
Add the my_delay.s to the project and in the main file add
extern void delay4(int loops);
#define delay_us(x) delay4(((x)*(SystemCoreClock/4000))/1000)
#define delay_ms(x) delay4(((x)*(SystemCoreClock/400))/10)
Then you can use delays like
delay_ms(100);
delay_us(162);
Note that this is not 100% accurate delay but gives an accurate enough result (if interrupted the accuracy will worsen of course)
It is a simple delay which is very convenient for cases like LCD delays where an absolute accuracy is not needed.
If you need high accuracy then a timer is the only way.
This code works in any cortex or ARM7TDMI
I wrote program with timer for gets (1s) delay , but it doesn't work :-(
I can't find what is the mistake!!
//crystal=12Mhz
//cpu clk=72Mhz
main(void)
 unsigned long int i;
 LPC_GPIO0->FIODIR=0X00000001;//P0.0 OUTPUT
 LPC_SC->PCONP=1<<22;//POWER ON
 LPC_TIM2->TCR=0X02;//STOP TIMER
 LPC_TIM2->PR=0X04;
 LPC_TIM2->TC=0X0;
 LPC_TIM2->TCR=0X01;//START TIMER
 while(1)
	 if(LPC_TIM2->TC>=0X0044AA20)//wait1s
	    LPC_GPIO0->FIOSET=0X00000001;
	    for(i=0;i<14400000;i++);//wait 1s
	    LPC_GPIO0->FIOCLR=0X00000001;
	    LPC_TIM2->TCR=0X02;
	    LPC_TIM2->TC=0X0;
	    LPC_TIM2->TCR=0X01;
Hello my friends
I want to use lcd TFT 2.4 with touch in my project
Would you please help me!!
Is there any library for them ?
Hello
I want to debug with jtag in uvision4 but I face with this error
how can I found AGDIRDI.Dll
Thanks in advance
Hi every body
I want to make flash magic programmer but I can't find flash magic programmer schematic
would you please help me to make it
