tony_lth
Advanced Member level 5
The VCO output out-band-pll is mainly determined by VCO performance. See the following simulation. Test1 pdf=3.25MHz, Test2=13MHz. Chip is ADF4156.
I attached two pictures, one is pll bandwidth is 2KHz. from the picture you can see that increase PDF from 3.25M to 13M, the PN @10KHz is same.
The other pll bandwidth is 20KHz, from that you can see that increase PDF from 3.25M to 13M, the PN improve about 6dB, that is caused by PDF X4 effect.
Maybe Mr. fenfei should give more details on VCO, Chip, PLL, OpAmp, etc.
