semiconductor
Full Member level 4
I was assigned an analog circuit design.
1. Algorithm to solve the following equation using integrators:
(the equation is given as picture that I upload here)
(Block diagram to explain the algorithm you apply)
2. Design a circuit (using integrator) that can generate a sinusoidal waveform
- Frequency range: 0.1Hz - 100 Hz (devide into 3 frequency band)
- Output voltage: 5 Vpp
+ about the first question, I haven’t found the solution yet. Can someone here can recommend me the way that I can find out the solution or if you can, please upload some related documents that is useful.
+ about the second question, Can you recommend me some useful websites that deal with this functional circuit. Or can you suggest me some ways to design this circuit
I look forward to hearing from you elektroda members.
Thank you in advance!
PS. Because my english is not good, if there’s something that is not clear, you can post here so I’ll try to give you other words that is more clear!
