[SOLVED] I need library for CMOS 0.18um
I found 0.18um tech file.
  • 0.18um tech file.zip
Reactions: Birillo
    Birillo
notice if have error, in simulation, create a folder in below address
D:\program arshad\arshad2\hspice\ookk\Hspice_model_files
and copy "mm018.l" to that.
I notice it, because I have problem with this file, and solved by copy the file to above address.
also I found another model, that can easily change Length of CMOS Transistor. and support 0.18um tech.
I put two examples in the first lines of file.
  • CMOS_models.sp.zip
Reactions: Birillo
    Birillo
I need also library file for cadence virtuoso IC615 !!!
thanks
