how to write a mikroc code for ultrasonic sensor
ok friend thank you
if you tell it tomorrow it is a priceless help for me
hey i wrote this.. might be crude but here goes..
T1CON = 0b00110100; // config timer refer page 79 of datasheet
im using timer 1 here.
here we use prescalor of 8, and the internal clock ,precisly fosc/4
so one increment will be (let the crstal you use is 8mhz)
8m/(4*8) ie 250000hz or 4us
distance traveled by sound is about 343 m/s (in air at 20degrees) so for every 4us that will be
1.372 mm
PS. the sound is reflected back, double distance ;) so we have to divide the value from timer
with 2.
heres the proteus design
View attachment ultrasound.rar
char txt[6];
#define TRIG PORTB.F6
#define ECHO PORTB.F7
// Keypad module connections
// End Keypad module connections
// LCD module connections
sbit LCD_RS at RD2_bit;
sbit LCD_EN at RD3_bit;
sbit LCD_D4 at RD4_bit;
sbit LCD_D5 at RD5_bit;
sbit LCD_D6 at RD6_bit;
sbit LCD_D7 at RD7_bit;
sbit LCD_RS_Direction at TRISD2_bit;
sbit LCD_EN_Direction at TRISD3_bit;
sbit LCD_D4_Direction at TRISD4_bit;
sbit LCD_D5_Direction at TRISD5_bit;
sbit LCD_D6_Direction at TRISD6_bit;
sbit LCD_D7_Direction at TRISD7_bit;
// End LCD module connections
        double distance;
        float final_dist;
void main() {
  Lcd_Init();                           //Initialize LCD
  Lcd_Cmd(_LCD_CLEAR);                  // Clear display
  Lcd_Cmd(_LCD_CURSOR_OFF);             // Cursor off
  Lcd_Out(1,1,"UltraSonicxx");
  TRISB.F6=0;//port b.6 as out port
  TRISB.F7=1;//portb.7 as input from the module
    1.372 mm
    the sound is reflected back, so we have to divide the value from timer
    with 2
  while(1)
  //trigger signal to module
  TRIG = 0;
  delay_us(10);
  TRIG = 1;
  delay_us(10);
  T1CON.TMR1ON =1;   //start the timer
  TRIG = 0;
  while(ECHO==0);  //wait for echo
  T1CON.TMR1ON =0; //stop the timer (timer1)
  Lcd_Out(1,1,"UltraSonicxx ");
  distance = TMR1H + TMR1L;
  distance = distance/2;
  final_dist = distance * 1.372;
  Floattostr(distance,txt);
  lcd_out(2,1,txt) ;
  lcd_out(2,15,"mm") ;
  Delay_ms(500);
this code doesn't work correctly friend
it change distance but not relevant to distance
i think it shows the time
 * Distance calc
 *  pic 16f887a .
 *  Portrait orientation
 * FileName:        magvitron.mcppi
 * Dependencies:    timer 1
 * Processor:       PIC16F87A
 * Compiler:        MIKRO C PRO FOR PIC  V 1.65 (2009)
 * Company:         Edaboard
 * Software License Agreement
 * Copyright © 2011 xxxxxx  All rights reserved.
 * Author               Date        Comment
 * Manukrishnan        18/08/12        ...
char txt[14];
int distance;
int test;
//main function
void main() {
  Lcd_Out(1,2,"((--Distance--))");
  TRISB.F6=0;        //port b.6 as out port
  TRISB.F7=1;        //portb.7 as input from the module
  T1CON = 0b00000000;                                                           // config timer refer page 79 of datasheet
  INTCON =0b11000000;
  PIE1 =0x01;
    for 30 uS the sound will travel about 1 c.m.
    (we have a precision of 1c.m if you need to change by calculating the number
    of increment for the patricular length and then changing the calculation
    accordingly
    with 2
  while(1)
  if(test ==1)
   lcd_out(2,15,"*Error : Ovflw*") ;
   delay_ms(1000);
   test =0 ;
  trigger pulse to the module
  TRIG = 0;
  delay_us(10);
  TRIG = 1;
  end trigger, Start Timer 1
  T1CON.TMR1ON =1;
  End timer,
  TRIG = 0;
  Listen for echo
  while(ECHO==0);
  Gottcha!, turn timer off
  T1CON.TMR1ON =0;
  whats the distance?
  distance = (4*TMR1H)+(TMR1L/60);
  /* distance calculation, the timer 1 is
  used here, as the lower nibble of it overflows,
  it will increment the higher nibble.
  the incrementing will be @246 or at 150us.
  that corresponds to 4 cm, so we have to multiply the
  higher nibble with 4 and add it will the current
  value if TMR1L/60 for distance calculation.
  TMR1H=TMR1L=0;
  distance to LCD.
  inttostr(distance,txt);
  lcd_out(2,3,txt) ;
  lcd_out(2,11,"cm") ;
  Delay_ms(500);
  End routine
  check for overflow of timer1
void interrupt()
  if (PIR1.TMR1IF)
   test =1;
   distance = distance +1;
   PIR1.TMR1IF = 0;
hey i updated it ..
this might work with an accuracy of 1 c.m
i think according to this code it measure the time between send signal(trig) and received signal(echo)
is that correct?
Yes...
but where do you arm TMR0 TMR0_ON ? for counting.
What is your PIC reference 16F or 18F ..
     distance = (double)TMR0 * 4.352;
    wordtostr(distance,txt);
  lcd_out(1,6,txt) ;
you can't convert a double float as an unsigned int..
use FloatToStr function..
