How to use EMX Designer?
rickyLu
Newbie
Newbie level 2
It seems that the EMX Designer can only synthesize RF components when using the GPDK provided by Cadence for rapid adoption. My question is: how can I use the EMX Designer to synthesize RF components with other PDKs, such as TSMC's PDK?
Install and configure the TSMC PDK into your Cadence environment. The PDK usally comes with a set of libraries, models, and technology files specific to TSMC’s process nodes.
Thanks, I have already completed these steps, and for EMX Simulation, it works. However, for EMX Designer, I need a specific TSMC PDK so that I can synthesize RF components using it. My question is: how can I create such a PDK and link it to EMX Designer?
You have to extract process data (metals, dielectrics, vias). Then you'll have to create a new process definition in EMX Designer. Import layer mappings from TSMC’s techfile. Link the new process to EMX Designer. Then validate and automate for future use.
You have to contact Cadence and work with them to get the scalable models created that support the specific PDK and metal scheme in use. An EMX Designer library will then be delivered to you. The GPDK045 version available on Cadence downloads is just representative of the functionality that the tool provides.
@ahsrabrifat is not correct. You cannot just add a PDK into your Cadence environment and then take some steps yourself to get going with EMX Designer.
Write your reply...
LaTeX Commands Quick-Menu:
