danny davis
Banned
- Joined
- Mar 1, 2013
- Messages
- 627
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,296
- Location
- Hollywood
- Activity points
- 0
Re: Testing Diode leakage & transistor leakage
What do you mean in a non-conducting state? Once your apply a Test voltage to it, then it's conducting the junction and state and current will flow
Most DVM meter output a TEST voltage , is this high enough? on the Diode Mode it has a TEST voltage and on the Continunity Mode it has TEST Voltage. Are these TEST voltages high enough to test for leakage?
5. for bipolar transistors, connect the base and emitter together so it cannot have any bias current then measure any current passing through it.
You short out the base and emitter? and how to connect the DVM meter in series to measure the current if the base and emitter are shunted or shorted together?
6. some tests for bipolar transistors are done with the base left disconnected but still measure collector current.
So I put my DVM meter in series with the collect lead and the output load to the transistor? and turn the circuit on?
Can't transistor testers or semiconductor testers, test for leakages in circuit?
I think the Huntron 2000 can test semiconductors for leakages in circuit
3. to test leakage you apply a test voltage with the device in a non-conducting state and measure how much current flows. In theory nothing flows, that's why anything you meausre is called 'leakage'.
4. for diodes, you apply the voltage in the non-conducting direction and measure the current.
