How to start counter when sensor is activate
Yes led blinking one time with internal clock
This is the good point to rectify the issue
Learn by doing it
Can you imagine why it is blinking one time
Can you modify the code with internal clock to blink continuously
Learn by doing it
I don't know but if I use external clock or internal LED is blinking only one time
// PIC16F877A Configuration Bit Settings
// 'C' source line config statements
#include <xc.h>
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
// CONFIG
#pragma config FOSC = HS        // Oscillator Selection bits (HS oscillator)
#pragma config WDTE = OFF       // Watchdog Timer Enable bit (WDT disabled)
#pragma config PWRTE = OFF      // Power-up Timer Enable bit (PWRT disabled)
#pragma config BOREN = OFF      // Brown-out Reset Enable bit (BOR disabled)
#pragma config LVP = OFF        // Low-Voltage (Single-Supply) In-Circuit Serial Programming Enable bit (RB3 is digital I/O, HV on MCLR must be used for programming)
#pragma config CPD = OFF        // Data EEPROM Memory Code Protection bit (Data EEPROM code protection off)
#pragma config WRT = OFF        // Flash Program Memory Write Enable bits (Write protection off; all program memory may be written to by EECON control)
#pragma config CP = OFF         // Flash Program Memory Code Protection bit (Code protection off)
#include <stdio.h>
#include <stdlib.h>
#define _XTAL_FREQ 20000000 //Specify the XTAL crystal FREQ
void main(void)
    PORTD = 0b00000000;
    TRISC0 = 1;    //PORTC R0  pins are used as Input encoder
    TRISD4 = 0;    //PORTD R4  pins are used as output.LED
    TRISB1 = 1;    //PORTC R0  pins are used as Input. sensor
     //Loading starting value of counter 65486
    TMR1H = 0xFF ;    // High byte FF
    TMR1L = 0xF6 ;    // Low Byte F6
    //Set T1CON Register
    TMR1ON  = 0; // Stops Timer1
    TMR1CS =  0; // Oscillator is enabled
    T1SYNC =  0; // Synchronize external clock input
    T1OSCEN = 0; // Oscillator is shut-off
    T1CKPS0 = 0; // 1:8 prescale value
    T1CKPS1 = 0;
    TMR1IF = 0 ;  // Clear interrupt flag
    TMR1ON = 1; //Start Timer1
    while(1)
       if(TMR1IF ==1)
         RD4 = 1;  // LED ON
         __delay_ms(500); //
          RD4 = 0;  // LED OFF
            __delay_ms(500); //
          TMR1IF=0; // Clear timer interrupt flag
        //TMR1ON = 0; //Stop Timer1
          //reload counter
let me know the result since I should not have testing board
it should blink continuously
<xc.h> while(1)
       TMR1ON = 1; // Start Timer
       if(TMR1IF ==1)
          //Load Register
    } </xc.h>
</stdlib.h></stdio.h></xc.h>
#include <xc.h>
// CONFIG
#include <stdio.h>
#include <stdlib.h>
void main(void)
    PORTD = 0b00000000;
    T1CKPS1 = 0;
    while(1)
       if(TMR1IF ==1)
         RD4 = 1;  // LED ON
         __delay_ms(500); //
          RD4 = 0;  // LED OFF
            __delay_ms(500); //
          //reload counter
it should blink continuously </stdlib.h></stdio.h></xc.h>
I am at outside so would take some time to test code but I am sure 100% it would be work
Can you add sensor triggred code
What is this project ?
Is it wall follower robot (Micromouse )
Yes LED is blinking continousely but problem is, it's blinking while there is no input on RC0. and I want to incremet counter if there is pulses on RC0
Where the codes that you tested last
The OP has another thread covering the same subject.
This one will be closed.
