neazoi
Advanced Member level 6
Youu know you are already giving the inverted saw tooth !!! with exponential decay... I am just saying to extend it... I think you are meaning the huge negative pulse??
that can be easily arrested by putting parallel diode in the primary as chuckey said.....
Sure, I will try it indeed.
What if one does not want to use semiconductors at all? Is there any other possible way to do it other than supplying a inverse sawtooth input?
*I am sorry to push you, I just want to see the limitations here.
