How to program the Arduino to make the servo do variable speed movement?
Justinli
Member level 4
Member level 4
I bought an Arduino controller online and bought several bus servos to make a quadruped robot. I want to use Arduino to control the servo variable speed movement and can show it on the LCD display in real-time.
I found that the control program given by the store can only realize the uniform motion of the servo mode, and I would like to ask how to program the algorithm to realize the variable speed motion of the servo bionic.
A servo motor simulation .... only you know what this means.
They are very similar .... to what?
As long as the replacement servo ... I have no idea
that formal robot can also operate in this way ... what robot? Which way?
But I could be wrong and I might need more help from you. .... Without clear information I can't help.
I have no idea what you want to achieve.
Klaus
I did have an idea whether a quadruped robot could do variable speed motion, but I was almost completely ignorant about robots, so I bought the servo pretending to be the quadruped of the robot, and if I could control the servo to do variable speed motion, it would be the same as being able to control the variable speed motion of a quadruped robot.
Thanks for your enthusiastic reply too, maybe I need to learn a bit about how the servo works from the basics.
Nothing can beat that!!
--- Updated ---
Try this one as a start.
“Begin at the beginning," the King said, very gravely, "and go on till you come to the end: then stop.”
--- Updated ---
Yes, I will, thank you very much!
I have experience with servos for a model airplane. Control pulses vary from 1 to 2 milliSec in length. The controller sends about 50 per second. The arm responds about as quickly as you move the joystick.
If you want the arm to take a certain length of time to move to a different position, change pulse lengths in tiny increments (say by a few millionths of a second) during the desired timeframe. It's identical to the effect if we were to move the joystick slowly.
You can use a driver board that has all kinds of controls for the servo.
