how to plot radiation patter as shown in attached paper
vishal_sonam
Full Member level 3
Full Member level 3
Hello
i have worked on this paper using HFSS. My s(11) parameters are matching but i m not able to plot radiation patter as shown in this paper.
please somebody help me in plotting the radiation pattern as like as given in this paper so that i can compaire my results
i m not able to read the plot how to read it.
In this paper they have plot the radiation patter for 6, 7,8 Ghz but i dont know for what value of phi and theta should be choose to plot the radiation pattern
regards
vishal
  • 12.pdf
Please upload the HFSS file of yours so that i may run it on my pc and let you know if the results match...
i have attached my file
  • Ansoft.rar
Still wondering how you have got a good confirmation of s11 values when your trace(radiating element) doesnt even touch the port, and on top of it the solution doesnt converge after six passes. fix these two and you will be able to get desired radiation pattern.
Elchiquito
Elchiquito
i think i have sent you the wrong
sorry
i have to check it again
---------- Post added at 16:37 ---------- Previous post was at 16:19 ----------
what does it mean "adaptive passes did not converge based on specified data"
and yes i sent the wrong file
for the solution to be valid your passes have to converge. you will have to go higher up the passes when you set up the solution frequency, increase the number from 6 to 10 or more.
Elchiquito
hello
i have attached the correct file.
tell me if my radiation is matching or not.
  • Ansoft.rar
There are no similarities from what i have seen from the paper.
i don't doubt the paper, but a question to myself, how in the world would you get a radiation pattern similar to the one presented in the paper with a printed monopole? seriously baffled.
Elchiquito
Elchiquito
hmmm ok
can you please tell me for what value of theta and phi you plot the radiation pattern
suppose if i set the frequency 6GHz so what value of theta and phi will i set.
or i should select all theta value and all phi values.
Vishal
Here is what i want you to do, Grab a ball and get a feel for yourself about theta and Phi. hold the ball against a corner of the room with height being your Z-direction and then x and y would be the your floor in accordance with the left hand rule.
so when holding your ball you will see that you can form a sphere using two circles one parallel to the height and one parallel to the floor. when you hold one stationary and run the second along the periphery of the first one.
do the same with the second one held stationary and first running along the periphery. when done together you have a sphere, this gives you a good understanding of the theta and phi.
so when you plot 2D radiation pattern you are plotting either phi for fixed values of theta or phi for fixed values of phi
normally you would plot theta for fixed values of phi=0 and 90 or anything else
for the example of a dipole or monopole you plot theta for a fixed value of phi and then phi for a fixed value of theta.
Hope that helps
Elchiquito
Please Elchiquito sir, kindly correct me wherever i am wrong:
for E-plane radiation patterns:
phi=0, plot Etheta v/s theta-----> co polar curve
phi=90, plot Etheta v/s theta----> cross polar
for H-plane patterns:
phi=90, plot Ephi v/s theta-----> co polar
phi=0, plot Ephi v/s theta------> cross polar
Please be specific in the reply, as i am having this doubt on which component to plot to obtain the correct plots.
thanks in advance.
Ashish
here we go. our example here is a patch, E-field is in the direction of the field lines, so theta=90 for variable phi is E plane, H-plane is phi=0 and theta=0 to 180. and the polarization of the patch antenna here is horizontal polarization, right? since the polarization is the trace of the E-field line.
Co polar curve for E field is theta=90 for phi, horizontal polarization, what would be the theta(cross polar) which would make it vertical polarization, theta=0 right.
Similarly for H-field co polar curve phi=0 for varibale theta what would make the polarization orthogonal phi=90(cross polar curve)
Hope that helps man.
I tried my best, and believe me i am not a good teacher have experienced it myself. if you find it difficult to understand kindly let me know one more time
Elchiquito.
