How to measure/detect the electrical activity of the brain ?
samsuffy
Member level 4
Member level 4
Brain activity
Does anybody have info about how to measure/detect the electrical activity of the brain ?
Which kind of sensor ?...
rem : it should be affordable... so, don't advice me "magnetic resonance" and stuffs like that !... :lol:
thanks.
Brain activity
Try:
**broken link removed** - here You can find simle EEG amplifier,
Or check - Link section on this site ...
conductive gell
Most skin electrodes use a conductive gell to keep the electrode to body resistance low and constant. Otherwis the electrode noise is larger than the body signals.
Methods to remove EMI from the power line radiation are used. One is to use differential signal electrodes. Another is to have a common mode electrode on a different part of the body.
The amplifiers should have low noise and high input impedance and low bias current.
You may need to use DSP or other filtering methods to block out all frequency ranges not involved with the desired signal.
