How to make a password verification system?
glenjoy
Banned
Advanced Member level 3
Philippines
I am doing a security system and having a problem on coding techniques.
I am using a numeric keypad.
1. I will input the pin numbers on the keypad, but how to store them? Byte by byte so I have to create an array of variables and increment them each time?
2. How to compare them and the stored numeric password?
thanks.
I don't see any problem in this, if you know the number of maximum people that will use the system you can allot the memory for it, with 1 place reserved for a pointer variable that points to the end of the current list. Whenever one enters the pin, just search the list for a match.
if you want to use a PIC you should check the PIC controlled intruder alarm that came in the April 2002 issue of EPE. that might give you an idea
password checking routine assuming 6 character long password When you read keys call this function and check its return value .
0 means password match
1 continue key input
-1 password did not match
-2 input overflow
static char str[7];
static char pos =0;
static const char *psw_p = "WELL";
char CheckPassowrd(char key)
if (key == CHAR_ENTER)
str[pos] = 0;
pos = 0;
return (strcmp(psw_p, str)==0)? 0 : -1;
if (pos = 6)
pos = 0;
return -2;
str[pos++] = key;
return 1;
To store data from keyboard, you need a keyboard buffer.
To handle verification, you need to compare the current buffer with actual password.
Go to http://www.geocities.com/issaiass/ and navigate to "Notas Tecnicas", intermediate section, and search for the LCD + KBD paper.
