how to install s@nop@sys , cad@ence tool in LINUX7.3 or 8.0
Re: how to install s@nop@sys , cad@ence tool in LINUX7.3 or
in some cases, you need to copy gunzip to uncompress as root to make some scripts work.
How many times you want to post?
Seems you like to posts at least twice here....
Electronlover,
I have managed to run NCSU kit also on Linux 7.3 and 8.0. They work perfectly.
T Zul
i also meet that problem before, that is because you havn't give the install program the files for the specified platform, like linux
no problem runing in 7.3, just follow the install document, you can run it
I think you can try SuSE pro linux v9.0.
It's better.
hello,
I am using syn_2002.05 on linux7.0. but it gives me an error when I try to analyze verilog designs:
Verilog option not available.
Even though VHDL designs work. I have removed LSI features from the license file as suggested by some people. but it still doesn't work. Any suggestions.
_________________
s0shinde
o 8-bit PseudoColor Visual is not available (default Visual option).
\o Using 24-bit TrueColor Visual.
\o The program xdpyinfo can be used to verify the Visuals available
\o for your display.
Any suggestion.
