How to get SAIF file ?
alpacinoliu
Member level 3
Member level 3
I am studying primepower of synopsys! Question is how to get saif file ! Anybody maybe give me some specs about saif!
thank you in advance
vcd to saif
dump vcd from netlist simulation convert vcd to saif using synopsys utility "vcd2saif"
how to generate saif file
You can also use simulators supporting Synopsys PLI interface for SAIF generation like NCverilog, VCS, ModelSim.
saif vcd
ur SAIF is prime source of generating dynamic power estimation for ASIC. Test stimulus must be proper for getting a near real power estimation. once simulation is done, dump the VCD file and convert VCD to SAIF using vcd2saif and input this to primepower along with netlist for getting the power estimation.
saif ncverilog
whether I need to configure simulators, Ncverilog or not , how to configure it !
thanks for your replying
Added after 6 minutes:
when to estimate static power , how to generate the saif file?
synopsys saif
For static power analysis, SAIF is not a necessary input.
Leakage power report depends on the library(.lib) used,
if the leakage power in the library is not state-dependent,
then no SAIF is needed.
However, if the value of cell leakage power is state-dependent
in the library, then the SAIF used for dynamic power analysis
can be also used for leakage power analysis.
Reactions: Morell
    alpacinoliu
    Morell
modelsim saif
AFAIK except VCS all other simulators that support the PLI interface need to be configured in terms of giving them an additional parameter which shows the path to PLI library file. For example for NCverilog on SUN platform you need to add the following command-line parameters when invoking NCverilog:
ncverilog +loadpli1=$SYNOPSYS/auxx/syn/power/vpower/lib-sparc64/libvpower.so:saifpli_bootstrap
where $SYNOPSYS is an env. variable containing path to your synopsys tools directory.
vcd or saif format
thanks for all reply aboved
anybody can post a script on pp involving static and dynamic analysis , which is a plus for me
Added after 9 minutes:
For dynamic analysis , whether I only read into vcd or saif files . are sdf or spf files necessary ?
vcs pli saif
That's correct for Synopsys PLIs availble for Simulators to produce *.saif.
For details how to do this:
please how can i use vcd2saif !!
help pleaase
