How to Find Capacitance between Coil, Magnetic Core and Shield.(Need Help)
Xeeshan143
Junior Member level 3
Hello I want to Find the Capacitance between the Coil, Magnetic core and Aluminum Shield in HFSS, Please help me out, how can I found the capacitance between each part. I will be thankful to your kind reply.
Thanks
Could You Please Elaborate it,,,,, I donk know need help......Please help me out in that....!!!!
I imagine the equation may be different for cylindrical structures
as field lines converge / diverge. Maybe not by much if "d" << r
(radius of curvature, of the "plates"). Toroidal may compound this
(two curves). And there, also the outer face becomes sparse (not
"plate". But I expect you could "unroll it in your mind" and get a
parallel-plate-squashed-flat approximation that would be a
roughly right value (finer points aside) to check work.
I gather the object of the exercise is for the student to learn HFSS,
rather than the practical value of measuring real stuff in place of
simulator noodling. If this was a real physical assembly then the
measuring could have been done long since.
But the little I know about HFSS, is that it should work from a
physical mesh (FEA) and figure it all out so you avoid solving
equations by hand where it's impractical due to complexity /
influence of picky details.
So I'm not sure any relevant (i.e. concisely answerable) question
has been asked. Might as well ask "how do I design a radio?".
Of course there are resources like Wiki and the ANSYS web sites....
