- Joined
- Jan 22, 2008
- Messages
- 53,659
- Helped
- 14,809
- Reputation
- 29,911
- Reaction score
- 14,422
- Trophy points
- 1,393
- Location
- Bochum, Germany
- Activity points
- 303,418
Re: How to find an audio transformer, step up from 8ohm to 1
Power ultrasonic drivers, as far as CW operation is intended (e.g. ultrasonic cleaning or "welding" of thermoplastics) are usually resonant circuits, simple ones often self oscillating designs. The transducer capacitance can be compensated by an inductor to reduce the reactant currents to be carried by the driver. If a series resonant circuit is used, a 1:10 voltage step up ratio can be possibly achieved without a transformer.
The discussed Apex and similar high-voltage power amplifiers are good for wideband and pulse applications, but not actually needed for a simple CW generator.
In any case, you should know the exact transducer specification. Apart from impedances and maximum electrical ratings, there are possibly also mechanical requirements, e.g. an initial force for safe operation. This is due to the fact, that the tensile strength of piezo material is limited and can be easily exceeded in resonant operation.
