ants
Full Member level 4
I need to find an audio transformer.
I will attach an LM3886 audio amplifier to the audio transformer and the transformer will power a piezo.
The LM3886 doesn't like capacitive loads and the piezo is capacitive, hence the transformer is isolating the two. The transformer is also shunting the piezo with inductance to allow power transfer.
The LM3886 will have an input of 1Kohm and wants an output at 8ohms. Essentially therefore I need a audio transformer that is 8:1000 ohms, stepping up.
I can't find one, and I don't have the equipment or time to make one. Can you help?
I have attached a schematic of the circuit I am building and the datasheet for the LM3886. Also the gain bandwidth product for my use at 130KHz is fine.
Thanks for your time and I will reply promptly to suggestions.
Regards,
Ant.
Regards,
Ant.
