monicajvis
Newbie level 1
![Newbie level 1](/styles/images/ranks/alevel1.gif)
You can use https://www.converttoword.com
cedance said:password said:I have an unlock pdf file. It contents text file because I can select text there. Because of some reasons, there are text I want to replace by another but I don't know how. The only thing I can do is insert comment lines!!!!!! They do not appear on the pdf file untill the mouse is over.
The text I want to replace in table so it CAN NOT be done by convert to Word then convert back to pdf. When I save as a word file, it's structure is damaged heavily.
Please help.
Only thing I can do right now is convert them into picture then using photoshop to edit. This would cause the file size is too big.
Thanks in advance.
hope this would be of use to u.. a book abt everythin on pdf. take ur own time to read it and solve the issue!
Code:http://bitchx.ufobject.com/books/how2doeverything/MCGraw-Hill%20Osborne%20How%20To%20Do%20Everything%20With%20Adobe%20Acrobat%206.0.zip
/cedance
