[SOLVED] How to design variable resistors R0 to represent the frequency-dependent loss in ADS
thundrous
Junior Member level 3
I am trying to replicate a result of a paper in Advanced Design System software. It is mentioned that the resistance is variable and its equation is 10e-9f (GHz) + 5.
When I drew the resistance in the software and wrote the formula, a syntax error showed up.
Would you please guide me on how to enter this equation? Is there any specific module I need to enter inside the equation field?
Here is their equivalent circuit:
and here is the equivalent circuit that I drew:
I would appreciate it if you please help me.
Use equation based s-parameter blocks.
Define first s-parameters matrix of a series resistor then enter these values into equation based blocks with the variable "freq". Otherwise it will not recognize.
Thank you very much for your response, until now I updated the equivalent circuit as follows, but still I cannot reach the proper data. Do you have any idea where the problem is? Also, i do not know how to introduce the frequency as the variable "freq". I tried to but the software does not accept it.
any suggestion appreciated.
S-parameters matrix of a series resistance ;
Here Z=R in your case.
Then use equation based s-parameter block like this.
then you will see that s-parameters are not constant versus frequency. (If the resistance was constant, s-parameters should have been constant too but they aren't due to frequency dependence of the resistance)
Thank you very much for your guidance I did what ever you mentioned in the previous comment as follows based on my current device and here is my Equivalent circuit:
S21, S11 are my experimental results and S65, S55 are for the simulation
I've got a good verification between S21 and S65, However the S55 does not seems good and it starts from -10dB
So based on the article I changed the frequency loss resistance depedance as follows: I eleiminated R=50
then the slope of S55 changed but still it starts from -10dB. It seems the variable Rlossy has lots of effect on our measurments and by changing the formula i even needed to change the capacitance C4 for validation between simulation and experiment results.
Would you please guide mewhich one is current and where did I made a mistake because S55 should start from zero.
It was my own example, not real/your one. You have to define your own formulae by yourself. It might
be anything as you desire. I dont know the process that you've been working on.
I would model this as S1P data block, using Z parameters in real/imag format for easy data entry.
# GHz Z RIR 1.0
0.00 5 0
1.00 6 0
2.00 7 0
10.0 15 0
In ADS that S1P block is connected as a series element using both terminals (signal and ground).
I do not know, would you please explain more?
If it's a real resistor then it has real inductance and perhaps
modeling it that way gets you where you need to go. The
stated behavior seems consistent with that (though whether
a simple lumped, or more fine grained network suits your goals
I could not say)
