How to design controller of elevator by FPGA ?
ducbin
Newbie level 6
Newbie level 6
My project is design controller of elevator by FPGA. But i don't know from where.
Please help me.
I know FSM but it 's difficult to list states. Then to apply to FPGA, that 's problem for me. Please suugest me.
Ok, perhaps you just need a template :)
take a look at the FSM section of the design below.
This will perhaps help you with your problem.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity dff4 is
    Port ( Data_in    : in std_logic_vector(3 downto 0);      -- 4 input lines
           Data_out   : out std_logic_vector(3 downto 0);     -- 4 output lines
           LE         : in std_logic);                        -- Latch is open when LE=1, else it's closed
end dff4;
architecture dff4_arch of dff4 is
begin
  dff4_proc: process (LE)
  begin
    if rising_edge(LE) then
       Data_out <= Data_in;
    end if;
  end process dff4_proc;
end dff4_arch;
library IEEE;
entity cntr3 is                          -- counts frames 0 1 2
    Port ( INCREASE  : in std_logic;     -- increase the counter on the falling edge
           Data_out  : buffer std_logic_vector(1 downto 0));     -- 2 output lines
end cntr3;
architecture cntr3_arch of cntr3 is
begin
  cntr3_proc: process (INCREASE)
  begin
    if rising_edge(INCREASE) then
       if Data_out = "10" then
          Data_out <= "00";
       else
          Data_out <= Data_out + 1;
       end if;
    end if;
  end process cntr3_proc;
end cntr3_arch;
[b]--*********************************************************
library IEEE;
entity main_fsm is
    Port ( wrq   : in std_logic;    -- external data must be written to RAM
           wrack : out std_logic;   -- write acknowledge ( clears wrq status )
           we    : out std_logic;   -- write enable goes to RAM /we pin
           oe    : out std_logic;   -- output enable goes to RAM /oe pin
           uld   : out std_logic;   -- also: A16
           lld   : out std_logic;   -- also: mux, Din, CP, cntr
           clk   : in std_logic;    -- main system clock, c.a. 7.5MHz
           RESET : in std_logic);   -- active LO
end main_fsm;
architecture main_fsm_arch of main_fsm is
type STATE_TYPE is (                -- main reset state is UDRD
                    UDRD,           -- UPPER data read cycle ( UDRD = RESET )
                    LDRD,           -- LOWER data read cycle
                    IDLE,           -- no RAM write requested for this cycle
                    RAMWR,          -- RAM write cycle
                    WRQCLR);        -- clear wrq status cycle
signal CS, NS: STATE_TYPE;
begin
     SYNC_PROC: process (clk,RESET) -- This is the synchronous part
     begin
     	  if (RESET = '1') then
     	    CS <= UDRD;               -- asynchronous reset. this must be included for successful synthesis
        elsif (falling_edge(clk)) then
            CS <= NS;               -- register new state at clock edge
        end if;
     end process;
     COMB_PROC: process (CS,wrq)    -- This is the combinational part (complete case statement infers comb. logic)
     begin
         case CS is
            when UDRD =>
                lld <= '0';
                uld <= '0';
                we <= '1';
                wrack <= '0';
                NS <= LDRD;
                oe <= '1';
            when LDRD =>
                lld <= '0';
                uld <= '1';
                we <= '1';
                wrack <= '0';
              if wrq='0' then
                NS <= IDLE;
              else
                NS <= RAMWR;
              end if;
                oe <= '1';
            when IDLE =>
                lld <= '1';
                uld <= '0';
                we <= '1';
                wrack <= '0';
                NS <= UDRD;                    -- return to the beginning
                oe <= '0';
            when RAMWR =>
                lld <= '1';
                uld <= '0';
                we <= '0';
                wrack <= '0';
                NS <= WRQCLR;
                oe <= '0';
             when WRQCLR =>
                lld <= '0';
                uld <= '0';
                we <= '1';
                wrack <= '1';
                NS <= LDRD;
                oe <= '1';
         end case;
     end process;
end main_fsm_arch;
library IEEE;[/b]use IEEE.STD_LOGIC_1164.ALL;
entity wrequest is
    Port ( wr    : in std_logic;       -- /wr signal from the uC
           wrq   : out std_logic;      -- RAM write request to the FSM
           wrack : in std_logic);      -- reset the request
end wrequest;
architecture wrequest_arch of wrequest is
begin
  wrequest_proc: process (wr,wrack)
  begin
    if wrack = '1' then
       wrq <= '0';
    elsif rising_edge(wr) then
       wrq <= '1';
    end if;
  end process wrequest_proc;
end wrequest_arch;
library IEEE;
entity dff8hi is
    Port ( Din    : in std_logic_vector(7 downto 0);      -- 8 input lines
           Dout   : out std_logic_vector(7 downto 0);     -- 8 output lines
           ld         : in std_logic);                        -- load data on the rising ld edge
end dff8hi;
architecture dff8hi_arch of dff8hi is
begin
  dff8hi_proc: process (ld)
  begin
    if rising_edge(ld) then
       Dout <= Din;
    end if;
  end process dff8hi_proc;
end dff8hi_arch;
library IEEE;
entity hiz_buf is                                             -- three state buffer
           oe         : in std_logic);                        -- Latch is open when LE=1, else it's closed
end hiz_buf;
architecture hiz_buf_arch of hiz_buf is
begin
  hiz_buf_proc : process (oe,Din)
  begin
    if (oe = '1') then
      Dout <= Din;
    else
      Dout <= "ZZZZZZZZ";
    end if;
  end process hiz_buf_proc;
end hiz_buf_arch;
library IEEE;
entity dff8z is
    Port ( Data_in   : in std_logic_vector(7 downto 0); -- eight bits of four pixel colours
           Data_out  : out std_logic_vector(7 downto 0);  -- equals '1' if color LEQ frame
           ld_in     : in std_logic;   --
           oe_in     : in std_logic);
end dff8z;
architecture dff8z_arch of dff8z is
	COMPONENT dff8hi
	PORT(
		Din  : IN std_logic_vector(7 downto 0);
		Dout : OUT std_logic_vector(7 downto 0);
		ld   : IN std_logic);
	END COMPONENT;
	COMPONENT hiz_buf
	PORT(
		oe   : IN std_logic);
	END COMPONENT;
signal datai      : std_logic_vector(7 downto 0);
begin
	Inst_dff8hi: dff8hi PORT MAP(
		Din => Data_in,
		Dout => datai,
		ld => ld_in);
	Inst_hiz_buf: hiz_buf PORT MAP(
		Din => datai,
		Dout => Data_out,
		oe => oe_in);
end dff8z_arch;
library IEEE;
entity cmp2 is
    Port ( color   : in std_logic_vector(1 downto 0); -- Two bits of pixel color
           pix_out : out std_logic;      -- equals '1' if color > frame
           frame   : in std_logic_vector(1 downto 0));   -- from frame cntr
end cmp2;
architecture cmp2_arch of cmp2 is
begin
  cmp2_proc : process (color,frame)
  begin
    if (color > frame) then
       pix_out <= '1';
    else
       pix_out <= '0';
    end if;
  end process cmp2_proc;
end cmp2_arch;
library IEEE;
entity cmp2x4 is
           pixels  : out std_logic_vector(3 downto 0);  -- equals '1' if color LEQ frame
end cmp2x4;
architecture cmp2x4_arch of cmp2x4 is
	COMPONENT cmp2
	PORT(
		color : IN std_logic_vector(1 downto 0);
		frame : IN std_logic_vector(1 downto 0);
		pix_out : OUT std_logic);
	END COMPONENT;
begin
	Inst0_cmp2: cmp2 PORT MAP(
		color => Data_in(1 downto 0),
		pix_out => pixels(0),
		frame => frame	);
	Inst1_cmp2: cmp2 PORT MAP(
		color => Data_in(3 downto 2),
		pix_out => pixels(1),
		frame => frame	);
	Inst2_cmp2: cmp2 PORT MAP(
		color => Data_in(5 downto 4),
		pix_out => pixels(2),
		frame => frame	);
	Inst3_cmp2: cmp2 PORT MAP(
		color => Data_in(7 downto 6),
		pix_out => pixels(3),
		frame => frame	);
end cmp2x4_arch;
library IEEE;
entity big_lcd2 is
    Port ( clock_in   : in std_logic;       -- main clock signal : 7.5MHz.
           reset_in   : in std_logic;       -- active high Reset signal
           wr_in      : in std_logic;       -- rising edge means that the data from uC has just been written
                                         -- into the external 74xx574 latch.
                                         -- wr directly controls the /LE input of the 74xx574 latch.
           lld_out    : out std_logic;      -- output the CP signal to the LCD pannel
           uld_out    : out std_logic;      -- output the uld signal to the cpld2 uld_in pin.
           we_out     : out std_logic;      -- controls the /WE line of the RAM chip.
           oe_out     : out std_logic;      -- inverted lld signal
           ext_data   : in std_logic_vector(7 downto 0);
           ram_data   : inout std_logic_vector(7 downto 0);
           LD_out     : out std_logic_vector(3 downto 0);
           UD_out     : out std_logic_vector(3 downto 0);
           Frame_in   : in std_logic);   -- every new frame is marked with a rising edge.
end big_lcd2;
architecture big_lcd2_arch of big_lcd2 is
	COMPONENT dff4
	PORT(
		Data_in  : IN std_logic_vector(3 downto 0);
		LE       : IN std_logic;
		Data_out : OUT std_logic_vector(3 downto 0));
	END COMPONENT;
	COMPONENT cntr3
	PORT(
		INCREASE  : IN std_logic;
		Data_out  : BUFFER std_logic_vector(1 downto 0));
	END COMPONENT;
	COMPONENT dff8z
	PORT(
		Data_in : IN std_logic_vector(7 downto 0);
		ld_in : IN std_logic;
		oe_in : IN std_logic;
		Data_out : OUT std_logic_vector(7 downto 0));
	END COMPONENT;
	COMPONENT cmp2x4
	PORT(
		pixels  : OUT std_logic_vector(3 downto 0));
	END COMPONENT;
	COMPONENT main_fsm
	PORT(
		wrq   : IN std_logic;
		clk   : IN std_logic;
		RESET : IN std_logic;
		wrack : OUT std_logic;
		we    : OUT std_logic;
		uld   : OUT std_logic;
		lld   : OUT std_logic;
      oe    : OUT std_logic);
	END COMPONENT;
	COMPONENT wrequest
	PORT(
		wr : IN std_logic;
		wrack : IN std_logic;
		wrq : OUT std_logic);
	END COMPONENT;
signal wrqi       : std_logic;
signal wracki     : std_logic;
signal datai      : std_logic_vector(3 downto 0);
signal lldi       : std_logic;
signal uldi       : std_logic;
signal Frm        : std_logic_vector(1 downto 0);
-- signal ram_datai  : std_logic_vector(7 downto 0);
begin
	Inst_lo_dff4: dff4 PORT MAP(
		Data_in => datai,
		Data_out => LD_out,
		LE => lldi);
	Inst_up_dff4: dff4 PORT MAP(
		Data_in => datai,
		Data_out => UD_out,
		LE => uldi);
	Inst_cntr3: cntr3 PORT MAP(
		INCREASE => Frame_in,
		Data_out => frm);
	Inst_dff8z: dff8z PORT MAP(
		Data_in => ext_data,
		Data_out => ram_data,
		ld_in => wr_in,
		oe_in => lldi );
	Inst_cmp2x4: cmp2x4 PORT MAP(
		Data_in => ram_data,
		pixels => datai,
		frame => Frm);
	Inst_main_fsm: main_fsm PORT MAP(
		wrq => wrqi,
		wrack => wracki,
		we => we_out,
		uld => uldi,
		lld => lldi,
      oe => oe_out,
		clk => clock_in,
		RESET => reset_in);
	Inst_wrequest: wrequest PORT MAP(
		wr => wr_in,
		wrq => wrqi,
		wrack => wracki);
   lld_out <= lldi;
   uld_out <= uldi;
end big_lcd2_arch;
hi
read this power point file about you question
i hope that is benefit
