How to Design Airborne Aircraft Antenna?
P
ppop
Newbie level 1
Can anyone help me for designing airborne aircraft antenna?
Any helps or suggestions will be appreciated.
There are three cases. The first is very slow aircraft where you can put a stiff wire out from the metal skin. This can be a quarter wave vertical.
The second case is fast subsonic aircraft where you will have to put an aerodynamic covering over the wire.l
The hardest one is a supersonic aircraft where you will have to use a flush mounted antenna. These include a slot in the skin and cavity types.
The famous antenna handbook by Jasik will give you more details.
