how to convert 32bit vector to a number
1. You should be setting it to signed 16 fixed all the time, as thats what the number is.
2. you can output reals to a text file, but they get written in the scientific format:1.234e7
You'll have to write a custom function to make it more readible:
or just borrow mine:
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
  --Returns the size of the given integer as if it were a string in the given Radix
  function get_int_length(x : integer; radix : positive range 2 to 36 := 10) return integer is
    variable temp : integer := abs x;
    variable len  : integer := 0;
  begin
    if x = 0 then
      len := 1;
    end if;
    while temp > 0 loop
      temp := temp / radix;
      len  := len + 1;
    end loop;
    if x < 0 then
      len := len + 1;   --add extra character for -ve sign
    end if;
    return len;
  end function get_int_length;
  --casts a real to an integer, with or without rounding
  function real_to_int( x : real; round : boolean := false) return integer is
    variable ret : integer;
    variable temp : integer;
  begin
    if round then
      ret := integer(x);
    else
      temp := integer(x);
      --always round towards 0
      if temp >= 0 then
        --rounds positive numbers down
        if real(temp) > x then
          ret := temp - 1;
        else
          ret := temp;
        end if;
      else
          --rounds -ve numbers up
        if real(temp) < x then
          ret := temp + 1;
        else
          ret := temp;
        end if;
      end if;
    end if;
    return ret;
  end function;
  --Converts a real to a string
  --gives a string representation of a real if you dont want the enire M.FeE format,
  --and just want m.f
  function real_to_string(x : real; num_frac : positive; radix : positive range 2 to 36 := 10) return string is
    --mantissa and fraction as integers
    constant ABS_X            : real              := abs(x);
    constant MANTISSA         : integer           := real_to_int(ABS_X, false);
    constant FRACTION         : integer           := real_to_int( (
        ( ABS_X-real(MANTISSA) )*real(radix**num_frac) + 0.5
        ),--takes care of rounding
        false );
    constant STRING_LEN_M     : integer           := get_int_length(MANTISSA, radix); --length of mantissa
    constant STRING_LEN_F     : integer           := get_int_length(FRACTION, radix); --length of fractional part
    constant PAD_LEN          : integer           := num_frac - STRING_LEN_F;         --number of pad 0's
    function x_is_neg return integer is
    begin
      if x < 0.0 then return 1;
      else            return 0;
      end if;
    end function x_is_neg;
    variable pad_loop         : integer           := 0;
    variable i                : integer;
    variable ret_string       : string(1 to (STRING_LEN_M + STRING_LEN_F + PAD_LEN) + 1 + x_is_neg );
    variable neg_offset       : integer := 0;
  begin
    if x < 0.0 then
      ret_string(1)                 := '-';
      neg_offset                    := 1;
    end if;
    ret_string( (1+neg_offset) to (STRING_LEN_M + neg_offset) ) := int_to_string(MANTISSA, radix);
    ret_string(STRING_LEN_M+1+neg_offset)                       := '.';
    --pad out the string
    while pad_loop < PAD_LEN loop
      i                       := STRING_LEN_M + 2 + pad_loop + neg_offset;
      ret_string(i)           := '0';
      pad_loop                := pad_loop + 1;
    end loop;
    ret_string( (STRING_LEN_M+2+PAD_LEN+neg_offset) to ret_string'high) := int_to_string(FRACTION, radix);
    return ret_string;
  end function;
[/syntax]
thank very much ill try to work with that in my code later...but before i get to this step i have a strange problem in the simulation:
this is my code:
library IEEE;
use ieee.std_logic_1164.all;
use ieee.fixed_pkg.all;
--use ieee.std_logic_arith.all;
use ieee.numeric_std.all ;
entity  fixed_test is
port(
dudx   : in sfixed(2 downto -16);
dvdx   : in sfixed(2 downto -16);
u0     : in sfixed(11 downto -16);
dudy   : in sfixed(2 downto -16);
dvdy   : in sfixed(2 downto -16);
v0     : in sfixed(11 downto -16);
data_in : in std_logic_vector (19 downto 0);
data_out : out  std_logic_vector (57 downto 0);
clk   : in std_logic
end  fixed_test;
architecture behave of fixed_test is
signal out_x     : sfixed(12 downto -16);
signal out_y     : sfixed(12 downto -16);
signal in_x     : integer range 0 to 640;
signal in_y     :  integer range 0 to 640;
begin
process (clk)
begin
in_x    <= to_integer(unsigned(data_in(9 downto 0)));
in_y    <= to_integer(unsigned(data_in(19 downto 10)));
out_x<= (dudx*in_x)+(dudy*in_y)+u0;
out_y<= (dvdx*in_x)+(dvdy*in_y)+v0;
end process;
data_out <= to_slv(out_x) & to_slv(out_y);
end behave;
and this is my testbench:
library IEEE;
entity  fixed_test_tb is end;
architecture behave of fixed_test_tb is
component fixed_test
port(
clk   : in std_logic
end component;
signal s_in_x,s_in_y   : integer range 0 to 640;
signal s_dudx,s_dvdx,s_dudy,s_dvdy  : sfixed(2 downto -16) ;
signal s_u0,s_v0 : sfixed(11 downto -16);
signal s_data_in : std_logic_vector (19 downto 0);
signal s_data_out : std_logic_vector (57 downto 0);
signal s_clk : std_logic;
constant clk_period : time := 10 ns;
begin
DUT:fixed_test
port map (
		dudx    =>s_dudx,
		dvdx    =>s_dvdx,
		u0      =>s_u0,
		dudy    =>s_dudy,
		dvdy    =>s_dvdy,
		v0      =>s_v0,
		data_in =>s_data_in,
		data_out =>s_data_out,
		clk    => s_clk);
s_dudx  <=to_sfixed(0.7071,2,-16);
s_dvdx  <=to_sfixed(0.7071,2,-16);
s_u0	<=to_sfixed(296.5685,11,-16);
s_dudy	<=to_sfixed(-0.7071,2,-16);
s_dvdy  <=to_sfixed(0.7071,2,-16);
s_v0	<=to_sfixed(-75.9798,11,-16);
s_data_in	<= std_logic_vector( to_unsigned( s_in_y, 10 )) & std_logic_vector( to_unsigned( s_in_x, 10 ));
--s_data_in	<= std_logic_vector( to_unsigned( 0 , 10 )) & std_logic_vector( to_unsigned( 5 , 10 ));
process
begin
    s_clk <= '0';
    wait for clk_period/2;
    s_clk <= '1';
end process;
process(s_clk)
begin
if s_clk'EVENT and s_clk='1' then
    if s_in_x<480 then
      s_in_x<=s_in_x+1;
    elsif s_in_y<640 then
      s_in_x<=0;
      s_in_y<=s_in_y+1;
    else
      s_in_x<=0;
     s_in_y<=0;
    end if;
end if;
end process;
end behave;
i wrote a testbench that each clock enter to my code a different coordinate (in_x,in_y) as integer (example: (0,0),(1,0),(2,0),(3,0)...(640,480))
to in_x and in_y..and my code need to do a calculation and put the resulte out to out_x and out_y...
the code work ok in the first 4 coordinats (0,0),(1,0),(2,0),(3,0) but from (4,0) i get the same result as (3,0) coordinate ...and nothing change in the result
only when the testbench get to (0,1)...the code give me a good result again in the output..but again when he get to (4,0)coordinate and up he give me the same resulte as (3,1) coordinate..
and so on...
i dont know what i'm doing wrong :sad:???
can you please help me with that
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
  begin
    if x = 0 then
      len := 1;
    end if;
    while temp > 0 loop
      len  := len + 1;
    end loop;
    if x < 0 then
    end if;
    return len;
  begin
    if round then
      ret := integer(x);
    else
      temp := integer(x);
      if temp >= 0 then
          ret := temp - 1;
        else
          ret := temp;
        end if;
      else
          ret := temp + 1;
        else
          ret := temp;
        end if;
      end if;
    end if;
    return ret;
  end function;
  --and just want m.f
        false );
    begin
      else            return 0;
      end if;
  begin
    if x < 0.0 then
      neg_offset                    := 1;
    end if;
    end loop;
    return ret_string;
  end function;
hi
i was wondering what type i need to send to your function and what im getting as a result?
basically i have 2 Sfixed signal (14 downto -16) that i want to write to a file as a real numbers( for example 563.1212 or -896.2548)
can you please tell me what type my signals need to be to use your function?
thanks
BTW i did some debugging for my code ans i succeed to use the sfixed types (im geting a "trancuted" warning but is ok because im getting a correct result) ...so thanks for the help i'm learning alot from your help
