alexan_e
Administrator
I assume that you are asking for the real circuit because the 555 model in proteus doesn't turn off.
Your relay can only control the direction of rotation , how do you expect to stop the motor?
It can only be stopped using the switch close to the motor supply and this is not controlled by the 555, it is a manual switch.
The motor voltage should be the operating voltage of your motor, is should have some specification, this voltage is irrelevant to the relay voltage.
Alex
Alex
