Photodiode reverse voltage depends on your application (light wavelengths and input power). Built-in voltage would be enough for UV to blue light, but for all visible (plus IR) light you'd better use extra reverse voltage. It also depends if you need/use an opAmp for gain - or not. For realization it's also necessary to know in which layers of your IC design the photodiode resides.
